For a long time my Stag has started ok on choke but would immediately start running very rough and lumpy until I was able to warm it up enough to push the choke in. After that it ran ok. The other day I was looking around the engine with the air filter off from the elbows and just happened to put a spanner on the accessible nut out of the four that secures each carb body to the pedestal mounting. On both carbs I could tighten that accessible nut down about half a turn. The others are difficult to get at so I put the air filter back on and started the car. The result was astonishing with the car running much as it should on choke for the first time in ages. I have since tried to check the tightness on the remaining nuts and could just get a spanner on a couple of them and they seem to be ok. Why did a half turn that one nut on each carb make such a difference and any tips on how to get to the others? Many thanks in advance. John
Lumpy choke issue.
Originally posted by The cobbler View PostI'm so glad you posted this, I've only owned my stag for a week, and every time I start it, it's just as you described, I'm going to check my carbs and nuts tomorrow, hopefully I will find the same issue.
