Has anyone got a photo of the gearbox top cover showing the reverse and overdrive switch locations? 'J' type overdrive.....I managed to install mine in the car with the switches wired the wrong way around - now I have reversing lamps in 3rd and top gear, and can only select overdrive in reverse!! I need to plan the easiest way to swap the wiring - without removing the exhaust and dropping the gearbox. Grr!
Gearbox top cover photo?
Yes, of course - that hole in mine has gaffer tape over it at the moment, so thanks for reminding me it is there! I was fearing that I'd have to take the exhausts off and lower the gearbox to get those switches corrected and I wasn't looking forward to that at all. You have reassured me that the mistake is not going to delay the rebuild too much at all.
Thamk you!Richard
Great photo from Gaeda.
be really good to have access grommets for all switch locations…. Not just auto inhibitors etc.
last time I posted a picture of this it was apparently from a tr6…. Which isn’t the same apparently.
… seems bonkers.
reminds me of working on a Jensen interceptor… the no 7&8 spark plug was accessed via the transmission tunnel… which was enormous to allow the torque-flight transmission to fit.
sorry to say, I think reverse & overdrive selection is a fatal attraction, so to speak.Last edited by jbuckl; 22 October 2023, 19:47.
Originally posted by jbuckl View Postreminds me of working on a Jensen interceptor… the no 7&8 spark plug was accessed via the transmission tunnel… which was enormous to allow the torque-flight transmission to fit.Richard
Originally posted by Gaeda View Post
In my case, it was original. I found several pictures of Stag gearboxes on the internet where there was also a screw in the "2-speed" hole.Richard
Originally posted by mole42 View PostHas anyone got a photo of the gearbox top cover showing the reverse and overdrive switch locations? 'J' type overdrive.....I managed to install mine in the car with the switches wired the wrong way around - now I have reversing lamps in 3rd and top gear, and can only select overdrive in reverse!! I need to plan the easiest way to swap the wiring - without removing the exhaust and dropping the gearbox. Grr!
