KYB front dampers
    KYB front dampers
    Hi guys I am wanting KYB front dampers to fit into the struts. Chris Witor mentions these are not for DIY fitting on his website.
    Does anyone know the reason for this ?
    Are they particularly difficult ?
    Tia Alan
    Hello Alan, if you're looking at product ID CW1280, could it be because Chris says "we re-machine the KYB base cup 2.5 mm x 118 degrees. This allows a fuller engagement of the nut in the thread at the top of the typical lower strut leg tube, thus reducing the likelihood of thread stripping" ?
      hi Philip, well CW supplies the damper with the bottom of it already reprofiled for better fitting. so not sure why he says after that not for DIY .
        Not obvious then Alan - maybe he's just covering health & safety re compressing the spring.
          Thanks Philip, I sent a message to CW and just got his reply.
          It is to do with removing the old dampers that need a special tool.
          Well I have already have done this and my struts are now stripped. I have literally just dropped them off along with the drag struts and the front subframe for powder coating.
          I am going to try rebuilding the struts myself. I will take an angle grinder if necessary to reprofile the bottom of new dampers if they do not fit low enough to get a full thread in there.
            Great, happy days
              I fitted them myself with no issues, not profiled ones either, they have a spannered nut on top to tighten them down, albeit rather thin steel nut , but I could work with them. Regards Graham
                Thanks Graham, it certainly sounds doable. I had some tips from CW too.
                I found various prices for the KYB dampers. Usual stag suppliers are quite dear. New pair from supplier on ebay £151. No vat and next day delivery with no postage.
                  I fitted a pair to my MK 2 a month or so ago. I found it necessary to grind a few mm off the bottom to increase the engagement of the retaining nut, a very simple job to do
