1974 Stag Autotrans fault
    Original BW Auto-trans. Intermittent fault started with not going into reverese from park. Drop into D then R and all good.
    Recently same issue, but now accompanied with a sound like 'a stick in the spokes of a bicycle wheel" but only in R. Sound still there even when
    I put in N and roll backward down a hill.
    Oil condition and level good..
    Thinking the Park pawl not properly releasing!
    Any thoughts?
    TIA
    I might be inclined to check the selector rod adjustment first, 1974 should have the venerable BW35 fitted. The ROM has detail on selector rod adjustment.
      OK, thanks Richard I`ll give that a go, just need to get access to a ramp, so it might be a few weeks before I can repost answer.
        +1
          Just Jacked car up and laid beneath. Adjust of rod was a little out, which I corrected, but this has made no difference.
          it's definitely road wheel speed affected, where in or out of R, fast the wheels turn, fast the noise.
            Originally posted by mole42 View Post
            +1
            +1
            unintelligible reply though.
