I have a spare Mk1 Stag engine mated to a BW35 gearbox. I was told the unit was pulled from a Stag as the gearbox failed. The engine has an early manifold on it. The type with the non-bypass thermostat.
I'm planning to get this engine running on a rig in my garage. I'm am not sure when the engine was last run. What are the chances of it running without the water pump leaking? I really don't want to put the manifold off. I do however have a later type manifold I can swap out. At the very least, I want to make sure the engine has good compression and oil pressure.
Sujit
Sujit
