Browsing Stag YouTube videos I found this one https://youtu.be/zAfyi75_zFQ?si=oC5CR9ZJj_78A9wi (and several more in a series) documenting attempts to locate the source of knocking/ticking in a stag engine. The conclusion is cam chain but this eventually proves incorrect.
A contributor In the comments section believes the noise is due to valves and recommends a special Saab tool (Nr 8391450) for measuring valve clearance and fixing the problem. This is said to be superior to the factory procedure.
I know Triumph and Saab engines share engine mechanicals. Curious to know what the Saab tool is and why it would be used. Also curious about the engine knock demonstrated in the video and said in comments to be caused by a valve. Can anyone elaborate?
