Today was the day I intended to start the engine in Mabel after the long process of putting the car back together.
First thing, check all the hoses are secure, then start to fill with 50/50 glycol and water - my usual coolant mix. I got to about 6 litres when I noticed a dribble of coolant on the floor, damn, I thought, I forgot to tighten something. Investigation showed that the coolant was dribbling out between the LH cylinder head and the block, all along the side. The right was weeping a bit too. I checked the head stud torques - correct at 50 lb/ft and still weeping coolant. Having followed the correct procedure (tighten RH head, fit inlet manifold, tighten LH head) when installing, using quality gaskets from R*mm*rs, I'm puzzled. It's not the first time I've fitted Stag heads but it is the first time I've had them weeping from the head gasket.
Before I left the garage today I've pulled the carburetters off, removed the inlet manifold, released and removed all the head studs and all but two of the bolts on each side and removed all the coolant hoses. I used up all my enthusiasm before I got under to drain the radiator and remove the exhaust manifold nuts so I haven't got the heads off but they are loose.
