This article in the December issue of the mag tells a long story of how the author found grit in the engine, and what he did about it. It says that "it must have been the powder coating" which seems obscure for those who don't know about this kind of problem, or am I being pedantic? Power coating itself does not cause grit to enter the engine. I think a clearer warning against grit blasting of cam covers would be much more helpful.
A further concern is that if cam followers (buckets) were badly worn by grit which embedded itself in the (soft) aluminium bearings, then most likely the grit is still there and may continue to wear the new cam followers.
