Hi everyone - I have recently lost power to a whole load of things - tacho, fuel & temp gauges, brake lights, indicators etc. Fortunately this didn't happen while out driving, just when I came to take the car out after not having used it for a few weeks. Simplistically it would all relate to a problem with the Ignition Control circuit, however there is power at the fuse and the fuse is good. There is no power at the 9-pin connector where the dashboard loom joins with the main loom, and checking with a meter for continuity of the green wire from the connector back to the fuse board, there is none. Seems that there is a break somewhere in this relatively short, straightforward path, but where and why? The wiring was all new when I put the car back together and everything has been working fine for a couple of years or so, until now. Does anybody have any suggestions for where to look next? Am I missing something fundamental?
Thanks in advance for any advice offered. Cheers - Dave
