Grilles n Vents
    Grilles n Vents
    Hi does any one know where I can get some louvres for my bonnet,
    I know Monarch do it but the price looks a bit stripey.
    SSsssssssssssssssssss
    Monarch only act as the middle man they use a firm in the se.I cant promise, as i had mine pressed in over 5years ago but will dig around and see if i can find the address. Its a must mod in my opinion.
    shaun
      Cheers shaun that will make interesting reading.
      I think that bonnet louvres are the way to go especially with the amount of heat build up under the bonnet and nowhere to go!
      But also they look so COOL.
      Ssssssssss
        try www.classicmetalshaping.co.uk
          Thanks I'll check it out
            why do you want louvres in the bonnet its a low pressure area they won't work are awkward to paint and keep clean and cost a fortune
            just my two penneth!
            Standard stag thrashed and enjoyed, Nissan Murano ( very underrated, very thirsty, very fast)
              Hi Chris, Thanks for your input.
              I'm no aerodynamycist so dont understand terms like low pressure area, is it because the airflows smoothly across the bonnet rather than being forced in through the nose?
              I crudely assumed that to let heat out the best thing was to put some way of letting it out.
              What are your thoughts? :?
              Still look cool though!
                if you get hot under the bonnet stuck in a jam , pop bonnet open and drive at low speeds, worked for me in the summer. I hear some chuck the rubber bonnet to bulk head seal to help with airflow. Root of the problem turned out to be viscous fan, looked smart new blades, spun freely etc, but it should only spin half a turn when flicked!:shock:
                  i wipe mine over and polish them with no hinderance and yes they do work very well. The shimmering air you can see when stationary proves they work well.
