Car related.
    Car related.
    Alternative cheap way of owning a right hand drive Stag, easyish conversion.
    Don.t even think about it.
      Believe it or not, that's how the right hand drive AMC Pacer was converted, except that they used a chain behind the dash, very strange. Martin.
        Ford Mustang 2 was done the same - a friend had one - steering slack was frightening !!
        Ray
          ... and who operates the indicator etc. on the steering column?
          Kind regards, Dieter.
            Exactly, Dieter. That's the only problem with it.
              The back seat driver.
                ... the one with the long arms and the short legs?
                Best wishes, Dieter.
                  sod the indicators! what about the pedals!:shock::shock::shock::shock::shock:
                    Look again at the photo, see the cross-shaft across the transmission tunnel in front of the gear selector, with "a suitable system of levers and linkages" just visible at far left to presumably operate the pedals.
                    As to "Why?", well it sure beats me. Belt instead of chain is mind-boggling!Don't think I'd even want to follow it, let alone drive it!
                      Bit confusing if you want to sound the horn!:?
