Since I put the engine back in my car I've had a weird problem with it. Starts perfectly well, runs well on the choke, warms up, all good. In traffic, if I push the accelerator a bit too fast, the engine backfires and can stall. Prior to the layup the engine was perfectly well behaved.
So far I've replaced the electronic ignition, coil, distributor cap, rotor arm and leads, timing is spot on 12 degrees. I've checked the carbs for leaks, dashpot oil is correct, made sure they are balanced and the mixture is good. I've checked the cam timing and valve clearances.
What have I missed?
What have I missed?
