thinking of fitting header tank
    Hi all,
    Thinking of installing a header tank once head gaskets sorted, just been looking at the one on wards site seem a bit pricey (£165)inc hoses but does look well made. has anyone fitted this particular tank and if so what do you think of it .
    I was thinking of fitting one too. I just wish it had a level switch, Terry
      Hello Terry,
      ...Or at least a sort of "looking glass"...
      Kind regards, Dieter.
        Yes that looks good Dieter but could it be fitted high enough? Terry
          Hello Terry,
          I am only thinking of adding such a "looking glass" to the EJ.Ward header tank.
            Would not a good quality re reinforced clear bottom hose suffice?, water level will be visible.
            Sukh.
              it looks like that belongs in an operating theatre !!!
                The reason Wards didn't have a sight glass fitted is that it weakens the integrity of the tank, that tube could blow off, all pressure would be lost and the engine would boil. Martin.
                  Yes, I have fitted one, see the pictures below on the page "Painted Header Tank"
                  http://stagownersclub.mywowbb.com/forum1/8215.html
                  You are right it is silly expensive for what it is. I dont like the square box look, I much preferred the blue tank also in the link, looks much better.I also think a level sensor should be in for this price. I also painted it the same colour as the car as not a great lover of thisdull chrome typelook.
                  What I really liked is their silicon hose T Peice, that is definitely good IMO. I wanted to change the top hose any hose so this was a good time to buy it.
                  Any further questionson the tank just let me know
                    Give over Martin!
                    Adding a couple of 1/4"BSP bosses would not weaken the integrity of the tank. If someone did use push-fit fitting like in the photo you can buy them suitable for the temperature, pressure no problem at all we use them at work for 10 Bar plus. However a sight-glass like I used, rather than a sight-tube I think is more appropriate.
                    Here is the link to the sightglass that I used for my custom tank, that could be retro-fitted to the Wards tank:
                    http://www.proalloy.co.uk/cgi-bin/si...mp;id=proalloy
                      Give over ? don't shoot the messenger, I'm passing on what the manufacturer said ! You're solution's not quite the same as two rubber elbows ! As for retro-fitting, at what cost ? Martin.
                        Just purchased a Volvo radiator header tank with level sensor, hopefully will be easier to set up than the Granada one.
                        Will keep you updated, could take a while after all the other jobs!
                          I had my level sensor wired to a high pitched buzzer, it went off on the way home after the rolling road, frightened the cr*p out of me, forgot I had fitted one,2 pounds inc postage.
