Hi all - thoughts please if you'd be so kind.
Reassembling the drive shafts - so here comes the easy bit .......wrong
The U/J's came from one of our well known suppliers. I've polished the bores for the outer cups within an inch of their lives so hadn't anticipated any issues. However, they were either tapped in or eased in with vice jaws nice and evenly, but some are great but a couple are tight-ish. All needle rollers had additional grease applied before any fitting commenced. On one joint the centre "cross", slides side to side one way but appears to be stuck over to one side in the other plane. It won't move but the outer cups are in place with the circlips attached. Is it me missing something here or are these U/J'S suspect?? Have fitted U/J's in the past both for myself and at work and never had this happen before.
Any thoughts appreciated as usual.
Gord
Gord
