The exhaust mounting bracket on the rear subframe has broken and will need to be welded. As it's the right hand side I'm concerned how close to the petrol tank it is and wondering how easy it is to just remove the subframe arm and then get welded. I've removed the whole rear subframe and diff before but not just one part.
I'm guessing I remove the exhaust, trailing arm and handbrake cable then remove the subframe arm. Has anybody done this is it a tricky job any advice would be appreciated. the exhaust knocking is driving me mad so need to get it done and don't really want to risk welding in place if you can even get to it or taking the whole rear end off.
Thanks in advance
Thanks in advance
