Quill Shaft wear
    Quill Shaft wear
    Anybody seen anything like this before ?. Diff side is fine with no notable wear, housing has no evidence of cracks.
    I wonder if the extension is slightly bent even if it isn't cracked
      I've put my spare in now, I'll see how it is in a couple of 1000 miles but ------>
      Having looked at my orginal diff subsequently, changed probably 5000 miles ago, the pinion nut was not tight & the spline could rock slightly. More likely to be that I think.
        On the original diff, it seems the nyloc nut was useless - gave no locking action all. New 5/8 UNF Nyloc & it seems ok now, was quite stiff to do it up, as expected.
        A replacement used quill shaft from Paddocks came today, has polished nicely on the seal surface & no sign of wear at all on the spline. Reassembled back into my spare extension housing (already with welded supports on it).
