Going madder than usual. Stag 's battery is draining . Cant find out where from. If I disconnect the neg from battery and meter this back to body I get 12 v Have disconnected Alternator all fuses out . I have an electric fan which has been disconnected. Fuse to EWP removed. Can not my get head around this at all. If any of you wizards out there can help I WOULD BE VERY GRATEFUL.
Battery drain
Do you have an ammeter setting on your meter? If so, disconnect the positive (+ve, red) terminal on the battery. Set the meter to the highest current range. Connect the meter between the disconnected +ve terminal on the battery and the disconnected +ve lead and see what current is flowing. The current will give an idea of what is causing the problem. So, if it is say 0.1 A then that equates to 1.2 W (a small indicator bulb).
OK back on it. I do not understand electrics at all.... Witchcraft. Anyway set my meter to 200 things with ignition control fuse out showing 80 things. With fuse in showing 200 things . So obviously some of this is the radio. Just wondering if I have the correct battery. Its a Hankook 12v 62AH 20 Hr 110 Min RC 540A EN. Any advice will be much appreciated. Thanks again in advance,
