Automatic Transmission Oil Cooler
    I am looking to for a replacement oil cooler as the existing one looks pretty bashed up and possibly leaking. I can't seem to find any in stock except for at Rimmer Bros. The part they have looks quite different with the cooling fins quite protected. Any advice or thoughts would be much appreciated.
    Oil Cooler Core - Gearbox - 311231 | Rimmer Bros
    I replaced mine last year with one from robsport, no problem in fitting or since. They appear to be in stock and cheaper than RB.
      Thanks APS, I tried Robsport and James Paddock both state the part is out of stock, I phoned RB this afternoon.
        Try Tony White.
          It’s one of those …. When every one else is out of stock…. The only choice is dimmers sorry to say.
          paddocks isn’t showing oos though
          Triumph Stag, Spitfire, TR6, TR7, GT6, Vitesse, Herald Parts and Spares Specialists
          2.
            Try Tony White.
            +1
              When you refit whatever you get, remember to use the flexible mounts to allow for expansion/contraction.
                Only one end afaiaa though.
                2.
                  Is Tony White SOCSpares or what are his contact details?
                    Tonywhite
                    He has loads of Stag spares. Mainly secondhand, but many NOS. He has a long running thread in the For Sale, Wanted, Swap section: https://socforum.com/forum/forum/sta...rs-of-hoarding
                    The Stag oil cooler is a simple item. The deformed fins can be straightened by carefully using a pair of long-nosed pliers or similar. A radiator specialist could advise on its repairability.
