After much testing and stripping out. Beginning to wonder if I have the correct battery. Have a Hankook 62 AH 110 mins 540A (Whatever that means. ) Draining about 580 milliamps, with battery control fuse removed draining approx 80milliamps.I realise the radio will contribute to this. No drain through Alternator. Any Ideas, !!!!!!
Battery drain
So if we assume the battery is providing about 13 volts and the drain is 580 mA that's about 7.5 watts - appears to be quite significant. Other than progressively removing fuses, the other thought is to borrow a clamp meter, or maybe buy a cheap one. It should serve as a non invasive way to track the drain, starting at the battery and working down the loom.
Clamp meter must be specified for DC current - starting price around £30, eg https://www.amazon.co.uk/Proster-Aut...hlbWF0aWM&th=1Originally posted by Philip Wardle View PostSo if we assume the battery is providing about 13 volts and the drain is 580 mA that's about 7.5 watts - appears to be quite significant. Other than progressively removing fuses, the other thought is to borrow a clamp meter, or maybe buy a cheap one. It should serve as a non invasive way to track the drain, starting at the battery and working down the loom.
My Stag has a modern radio with permanent supply to maintain memory and a Davies Craig Electric Water Pump. I've not noticed any significant battery drain from these, but ....White 1976 build ("Mk2") only a few mods
When you say you have removed all the bulbs (lamps!) did that include the one in the boot?? a 5W lamp will take close to that current and the boot illumination lamp can stay on with the lid closed and not be seen.
Also have you disconnected the alternator to rule out any faulty diodes in the rectifier/regulator?
The type/model/capacity of the battery will have no effect, drain on the battery is a drain on the battery !
I would disconnect one battery lead and put a 5w sidelamp bulb in series - i.e. connect one side to the battery terminal and the other to the now disconnected battery lead. If there truly is 580mA of current the lamp will illuminate. You can then go around disconnecting things and when you find the problem the lamp will go out.
DC Current clamps are not much good at low current levels and can often give misleading results.Now Stagless but have numerous car projects
- Likes 2
Iirc the cigar light is on a non ign controlled live.Originally posted by Mike J View PostThanks all Have disconnected Alternator no change to the loss. tomorrow will take puddle lights and foot lights out . got a hunch maybe cigar lighter. What ever it is its blooming frustrating
often it’s dead though!
could be a culprit .
have had trouble with boot lamp draining in the past on another members car.
