Having at last managed to remove and then refit the inner and outer wheel bearings, I am being frustrated by the difficulty reattaching the brake caliper. Each time I think I get into where it should be the back plate dust shield stops me winding in the bolt.
should I:
1. Undo the nuts/ bolts holding the plate, and refit after?
2. use emery paper to give slightly easier installation for bolts?
3. Should I lightly grease the bolt or use copper ease?
Incidentally I thought putting back together would be easy
					should I:
