Rear bushes
    Rear bushes
    Hi all, can someone who has done the rear suspension bushes on the swinging arm give me a run down on the procedure both sides n/s o/s Mk2 Stag Many thanks Tommy.
    Could maybe try a search for "trailing are bushes" or "rear suspension bushes" ?
      Ok if you need advice about fitting new trailing arm bushes. …. Here goes…
      I had to do some. I had little time to do them due to mot and a trip.
      i had spares in rubber and poly.
      i released the trailing arm.
      i used an 8 mm drill to drill out the old bush.
      i attempt ed to fit new rubber bushes using a pull in tool.
      no chance… would not go.
      swapped over to try new poly bush…. Slid straight in.
      job Done.
      just my 2 p
        Thanks jbuckl, sorry for the late response, can you explain how you jacked the car up and released the arms to change the bushes in this way in more detail please, this method sounds muich easier than the Rom.
          Jacked up on the big rear subframe mount.
          Released jacked up subframe onto a stand with wood.
          released trailing arm bolts x2
          pulled the arm free from the subframe brackets.
          bit of a tug needed.
          began drilling (recall 8mm cobalt drill)
          pulled out remains of the bush.
          cleaned up the alloy trailing arm bush hole.
          pushed in new poly bush (bare)
          pushed in tube / sleeve.
          aligned trailing arm to brackets (hardest part)
          required a pointed tool / old stout screwdriver
          refitted bolts x 2.
          hope that helps?
            Have also done the big subframe mounts in a similar way…. Without dropping the whole subframe….. one side at a time. If that’s useful / needed ?
              Thats great, be giving it a go very soon, thanks for your help.
                I did mine recently...
                I’ve just looked back at my blog about replacing the front bushes, and the first sentence is: “Before I start, I need to let you know that although this job (and hence the date of this …
                So remember when I had a mission of a day to get the rear trailing arm bushes done, and only got the nearside ones done because it took so long?? Well today I tackled the offside ones! I was a litt…
                Cheers!
                  Thanks Chix, appreciate your time and help. I bought my Stag as a lockdown project at the start of the Covid pandemic, i wasnt too keen on the colour but its grown on me and now i love it and i think it saved my sanity !!!!
                    Yes mate!! Exactly the same for me (as you may have seen on my blog!) - I knew very little about cars, let alone Stags when i first got mine, but I'm determined to do everything myself and it has been a lifesaver for my wellbeing, and like you, saved my sanity! All the best with the bushes, they are tricky but don't give up!!
                    By the way, I love the colour of your Stag!
