Stopping and loosing drive
    Hi guys I’m in need of some constructive advice!
    Basically I’ve just got a new to me Stag.
    It’s been off the road for approximately 5years.
    My first jobs involved checking all the visual stuff and oil level radiator levels etc. I couldn’t check the auto box level because I wanted to get it up to temperature. I was then confident enough to start her up and go for a steady drive. Initially I was very happy. Then after about 4 miles I was aware I was loosing drive ? Then on slowing down at junctions it stopped it immediately.started again but on selecting drive it would either struggle to set off or stop again. I had about 2miles of this before I could get to a garage. The guy was fantastic in the way he dropped a job to try and help me. I told him my story and he said let’s check the fluid level. It was Empty!! We proceeded to replenish the reservoir. I started the car ( first time) and selected reverse it immediately took up the drive. I then selected drive and it immediately took up drive. I was happy. I set off home approximately 2 miles. The last 1/2 mile it started doing the same things. I struggled to get home. Parked up turned it off and checked the fluid level. It was still up to level without ANY signs of a leak????​
    Your supposed to check the level with engine running I think - not me though, mine is a manual.
      What colour is the fluid, nice red colour usually
      If you select 1 does it take up drive? sounds a bit like the valve block on the gearbox is at fault.
