Bw35
    Bw35
    Hello
    I have a 52 year old mk1 with an oddity that I would like some understanding if anyone could help, the inhibitor switch is one from a BW65 are they compatible?
    Hi Adam and welcome aboard
    A quick scan of the parts manual which is helpfully reproduced on Rimmer Bros website suggests not
    BW35 - RTC1150
    Order your Triumph Stag Front Oil Seal - Inhibitor Switch - Sump and Parking Mechanism (Type 35) ⛽ Low prices and fast, worldwide delivery ✈ British car experts ♚ Call ☎ 01522 568000 or ☎ 1-855-746-2767
    BW65 - RTC36
    Order your Triumph Stag Front Oil Seal - Kickdown Cable - Inhibitor Switch and Breather Pipe (Type 65) ⛽ Low prices and fast, worldwide delivery ✈ British car experts ♚ Call ☎ 01522 568000 or ☎ 1-855-746-2767
    sounds like you may have a BW65 fitted
      Definitely very different switches.
        Thanks for the reply’s guy done a bit of research and some simple checks, it looks like the selector alignment is slightly off and it needs a bit of adjustment
          Be sure it still goes securely into the park position & holds.
