Magazine October includes article on mod to air inlet to help with electric pump - over many years and considerable involvement with Stags I have only twice experienced overheating with the standard well maintained water pump /radiator system, the first was when towing a caravan with an auto Stag and the second returning from Silverstone when the fan torque unit semi - collapsed so I have never seen the need to use an electric system and to then add rad shutters seems even less desirable.
The original system with good radiator and a high mounted overflow bottle WORKS so why go to all the trouble off electric, additional help can be given to standard system by use off low level indicator in overflow bottle, front spoiler to aid air ingress and rework of bonnet seal to allow air exit in heater inlet area.
Going further a case can be made for electric radiator fan and temperature sensor with timer relay to bring it on at correct times - the only use for an electric pump is if a small unit introduced to bottom hose area is wired in such a way as to assist circulation under extreme need but not as a replacement for a standard working pump.
don't forget many B.M.W.s, ford Granada's etc.used high mounted pumps without problems until loss of water for many reasons created the overheating.
Mike the Mechanic
Mike the Mechanic
