Monarch progressive springs and Gaz shocks
    Anyone bought and fitted these rear standard height progressive coils and standard Gaz adjustable shocks?
    Thinking of fitted these as want to stiffen up the back but without compromising on ride
    Are you going to put a light on top of the axle
      There always one
      No, all standard height coils, no room for a light
        Progressive springs are normally only used in the front Andrew. If you look at Chris Witors rear springs they are all non-progressive. The lowered kit I have is progressive on front but standard lowered on the rear.
        If you want to stiffen up then I suggest some adjustable shocks so you can set to how you want them but in all honesty I'd do the fronts too as a hard rear and a soft front will not feel good.
          +1 for Chris Witor.
          bad experience with nearly all other sources for spring offerings.
          Wrong height, wrong number of coils …. This has been the same for many years now.
          Front suspension rebuild takes a while to do…. So disappointed when you find out the parts are incorrect though.
          No experience of receiving monarch parts though…. Or answers either.
          chris Witor suspension parts seem better than all other offerings though.
          2.
            The GAZ are well worth the money for any Stag, They make a massive difference and can transform your car get it to handle how you want it. Instead of relying on some 50 year old part filled with spoiled contaminated oil with failed seals. My knees are only 55 years old and I'd gladly change them for a knew set, just saying
              GAZ +1
              Witor springs +1
                SPAX (perhaps similar benefits to GAZ?)
                Witor springs +1
