Can anyone help locate a lower steering column shroud, the ones with key entry on the RH side like the Federal Stags have? I have tried the usual suppliers with no luck.
In the mean time I have modified my existing lower cover as it was damaged and cracked anyway.
I cut a square section around the key entry hole and a corresponding square section on the opposite side. Using a repair gun for plastic, small metal staples were melted in the joins and then the gaps filled with melted down cable ties.
I now have the Stag set up as per most Aussie cars, Ie: Ignition key entry, Bonnet release and indicators on the RH side.
Any help locating a RH entry lower steering column cover would be appreciated.
