Relocating the alternator
    I bought the bracket for relocating the alternator from Tony White as he mentioned having some difficulty in getting parts manufactured going forward. I think this is a common modefication. Any advice or tips on doing this would be much appreciated.
    All you need is the bolts, belt and fly lead.
    Flylead available from ej wards.
    Securely route the lead.
      run main brown high current wires to the back of the starter motor. extend the brown / yellow around the engine bay to the new location
        I bought the extension lead from EJ Wards. My alternator was already moved to the high mount position on the LHS. I am rewiring the car as the PO had totally botched it installing a cutoff switch for racing.
        The new lead came with female terminals so I am puzzled about how to join it to the wiring loom as the new loom also has female terminals which would normally go to the alternator low on the RHS. Do I run the Ward’s lead directly from the alternator to the starter or do I change the terminals on the Ward’s lead to male?
          The loom and extension lead have female connectors because, originally, there would have been a black plastic double male connector clamped to the battery positive lead near the bottom of the RH suspension turret. This was the subject of a near miss thread recently.
          I've had my Stag for just over a year, done roughly 2500 miles in that time, though I'm using it a lot more this summer weather allowing. Up till the last couple of days it's performed perfectly and I'd got to the stage where I genuinely felt confident in it's performance and ability to get me places. The engine was rebuilt for
