Cross member bushes and nuts.
    Hi everyone, bought new polybushes for cross member but when pushed in they stretch, and I can’t get them to feed back in to make them flush both sides any suggestions greatly appreciated. Also the nuts that go onto the camshaft caps have a round ring on one side does this side fit against the cap. Many thanks Steve. IMG_0162.jpg IMG_0133.jpg
    Have a look on YouTube to find all the tricks how to do it. Round ring goes on the outside that's the locking bit.
      Hi, so when nut is on you can see it on the top. Cheers Steve
        help to know what cross member, looks like the steering rack mount area...
        ... If so then superflex I fitted to the cross member for mine were perfect
          Hi Richard,yes it is steering rack mount. The superflex one’s do they come in two half’s and pushed in from either end or are they one complete bush. Sorry if that’s a silly question but still learning. I’m now trying to teach myself how to work out shim sizes for cam followers all good fun. Cheers Steve
            polyurethane bushes, car suspension bushes, uprated car suspension, replacement car suspension bushes, suspension upgrades, polyurethane, bushes, suspension, polyurethane suspension, polyurethane car suspension bushes, suspension bushes, poly, urethane, supplier, distributor, superflex, car, parts, spares, Wells, somerset
            Are these the style of bush you have?
            shows each bush as a cotton reel, clean the inside of the hole on the cross member, lube up the bush and then squeeze one end of it into the hole, they are just flexible enough to do this by hand but if you strruggle you can try the thread rod. couple of big washers and 2 nuts process to pull it through. With a bit of wiggle it should work its way through and come out of the other end. once in place you can again lube up the steel shaft and slip that through the middle of the bush, these should just be a push fit.
            Couple of gotchas on this job;
            1. be sure to lube up the steering mount bolt before it goes into the bush tube to prevent it fusing as a giant lump of steel
            2. loosen the steering intermediate shaft in the engine bay, you just need to loosen the pinch bolts, the rack will go not go back into exactly the same location and the result could be that the shaft UJ run tight and give some unusual sticky steering feelings.
            Plenty of innuendo in there to get Beeb worked up into a frenzy
              An excel spreadsheet is the way to do the shims. I’ll send mine if it helps. Pm me an email address
                round recessed ring on the nut is to shift anything that might be between the nut face and the washer that is underneath it. always face the marked face of the nut to the washer. to outer face of the nut should be smooth
                  might even make a video of the job as I have a TR7 head on my bench at the moment
                    Face for radio
                      Face for radio
                      and a voice for the silent movie
                          Thank you everyone for input really much appreciated can’t believe I’m speaking to a tv star, Goldstar I will pm you tomorrow. Cheers Steve
                            Hi Goldstar, I have pm,ed my email to you. Cheers Steve
