Hello,
I refurbished for sure my 6 triumph stag motor and have a strange problem, after changing and demounting the whole motor,crankshaft, block cleaning new gaskets......and I let the motor turn, the
EVANS coolant came in the V and in through the STUDS (See picture), I suspect now that my NEW Thermostath is blocked,when the motors turns the leakages dry away, after putting the motor off,
the day after I se all the leakages through the studs and in the V under the manifold, so I suspect that the pressure can't go away and searched its way through the weakest points.
Am I right;;see pictures ,the motor has completely been refurbished and renewed and this is motor 7 and I never had such a problem!!!!
Thanks in advance for your reactions!!!
Greetings,
Luc
Greetings,
Luc
