Don't take the Stag out in winter unless the roads are salt free as I have a yard in which I can run the Stag around, forward and reverse till it all warms up then after a while back to the garage. No problems at all with the brakes. Went for a run this morning and gradually the brakes started to go soft with increased pedal travel so cut the run short and back to base. On opening the brake fluid reservoir the rear compartment is totally empty and the front only half full
. Been underneath as I have a pit and no telltale leaks seen or puddles of fluid. Using silicone fluid bytheway.
Any advice/suggestions gratefully received and possible remedies.
Many thanks
Maurice
Many thanks
Maurice
