I have an oil leak were the near side drive shaft enters the diff the off side is dry so is the Propshaft can you remove the drive shaft to diff seal and replace with the diff still on the car Thanks
Drive shaft seal
No, remove the output sub assy.
Remove the nut.
Press apart the shaft from the flange.
Then change the seal.
exchange / outright outputs available ready to fit.
https://socforum.com/forum/forum/stag-owners-club/soc-forum/25951-removal-of-drive-shaft-inner-hub
https://rimmerbros.com/Item--i-GRID005265
try td fitchetts in Telford for a unit
