Hi everyone,i have a small leak on the power steering pump,i replaced the high & low pressure pipes at the back end of last year-could it be that i've not bled the system successfully after the work i did ? or will it be a case of pulling apart the pump and replace all the seals? if so anyone done it-is it straight forward or a specialist job-i'm not avery confident mechanic!
thanks in advance!Dale
