Hi All
Trying to diagnose my MOD Stag with difficult notchy gear changes.
Mostly 1st to 2nd gear and back down.
Lots of various comments when searching on this site, mostly to do with bleeding and getting air out of hydraulics.
Which I hope I have achieved.
The clutch and slave and master cylinders were replaced approx. 15,000km ago
The bleed nipple is on top of slave cylinder and the piston was bottomed out during bleeding to reduce air in system.
The gear changes have never great but have no other MOD Stags cars to compare.
Currently with full clutch pedal travel getting approx. 15mm of rod movement from the slave cylinder.
Is this normal?
Trying to establish if a hydraulics or clutch issue!
I see some talk of smaller bore slave cylinders to give more travel, has others experience of these and their results.
Thank you in advance for all suggestions.
Is this normal?
