IMG_3181.jpg So I do have a weeping pump. Guessing o rings but hoping it's not the impeller seal as I fitted the high quality one and made sure the impeller seal surface was good. Fluid loss is pretty minimal but I think is getting worse. Pressure testing show a drop from 15 to 10 psi takes about an hour so do not a huge issue at the moment.
weeping
 ). Did you use viton O rings Chris?
