Got my Stag last year and is basically a very sound car,however noticed water
in Vee, not much, so just kept an eye on the water level.
Over the winter I investigate the problem and decided it must be the
inlet manifold gaskets so replaced them and also put well seal on them for extra security.
I also removed the water pump and decided in my wisdom it was fine, anyway
I refitted everything and ran the car till hot, fine no leak ,went for a run came back
had a look under bonnet. S**t water in vee. Off with inlet manifolds again, in the process destroying gaskets,so order more. Decide it must be waterpump send off for refurb.
Pump arrives back with all new gaskets.
Refit once again and when torquing up bolts managed to strip couple of threads.
So off comes the manifold again, guess what, new gaskets required,as managed to tear them again.
Order two sets this time. Decide to Tap and Helicoil all the threads to be on safe side.
First time I have tapped anything, all going well till I drilled one of the holes and realise it already has been Helicoiled. Spend next two days getting the mashed Helicoil out.,
Seriously thinking of taking a three pound hammer to the car now.
Leave the car for a couple of days to cool down, me, not the car. Finally get everything back together
I even managed to get the Dissy back in the right place, Start car and go for run, success no water leaks. But no happy ending have noticed in the last few days, no not water, but a a nice hazy blue smoke screen when I accelerate, so looks like an engine rebuild some time this winter, will order three sets of Gaskets now.
Sorry for rant enjoying car but slightly p**sed off.
max
max
Martin.
