Sorry to raise this again but hoping to get a response from someone who has actually mounted 3 point inertia belts successfully.
Searched and read all the posts, 2 of the mountings are already there and cause no problems but the third gives many options.
My preferred option would be to have the shoulder strap come over the shoulder in the center of the car to meet the buckle mounted on outside and then return across the lower body to the centre lower mounting. This would seem to be the 'wrong' way but sitting in the back it seems that if the strap came over the shoulder from the outside to the centre it is easy for the passenger to roll sideways out of the belt, fitting it the other way around the passenger cannot roll out of the belt as they are pushed against the seat side.
My preferred way, over shoulder in the centre, requires the retractor to be mounted either :-
1. in the lower centre and the belt pass out between the seat back and seat base or
2. mounted in almost the same place in the centre but the belt passing, vertically, up and over the seat back then down.
I'm gravitating towards 1 (see diagram below) as I cannot see the retractor being strong enough in the case 2 to pull the belt tight. If I made a custom bezel between the seat back and base to keep the seat cushions apart it should be a straight pull and keep the belt tensioned.
Now I have read, and agree with, all the fears of the seat back not being strong enough to avoid collapsing down in a big accident but I'm happy to re-enforce the seat frame by filling in the frame from the top rail to the base with 16swg steel sheet (still not perfect but considerably stonger)
The Belts I am thinking of buying are Securon 254
Thoughts? anyone mounted the retractor in the centre? - Alan
