Had a problem in that I was loosing water into the vee. Not just a leak, a lot of water. Pulled the manifold and because I have a Wards bung fitted with an external pump I left that alone assuming I had a failed manifold gasket. Rebuilt it all up and leak is just as bad. Different manifold fitted so it’s not the core plug. Need to have a look with a camera but from what I can see from above I suspect it’s coming from the pump area. Has anybody else had the o rings on the bung fail or similar problems with the brass bung and can a failed head gasket leak into the vee?
Inlet Manifold Leak again.
