Inlet manifold question
    I have an inlet manifold which has been modified to take a weber. The bridge between the two halves have been cut. I have managed to connect a ZS set of carbs on it. I think I have it 100% air tight. An engine I'm testing fires briefly when I put fuel directly down the cars, but wont continue to run. A suggest from Terry Hunt is to check the timing. I have not done that yet. The carbs were taken off a running car.
    The question is, besides each carb feed different bank cylinders, will removing the bridge hinder starting? I'm aware the original manifold has some small hole between the bridge.
    Sujit
    Missing bridge will affect distribution; should not affect starting.
