I have an engine on a test bed. I'm using a 3 ohm coil with no ballast and for now the distributor has points. I don't plan to run this setup for long, but will the 3 ohm coil burn out the points sooner than later?
I have my no. 2 plug wire on my regular stag on the cap. It is on the terminal of the cap to the right of the hold down clip. Is this correct or should it be on the terminal to the left of the hold down clip? I have the firing order right.
Sujit
Sujit
