Hi guys,
went for the bi-annual emissions test a couple of days ago. Set up the Strombergs to give me around 4% CO using my emissions tester.
When the test centre (like MoT) hooked up the car it started reading nutty values like 7%, then dipping for a second or so to 1%. This went on for a couple of minutes until I said I'll try to reduce the idle mixture. Basically nothing worked as planned and the emissions values just kept dancing around no matter what I did to adjust the needles.
Anyway, the tester just made a note Emissions:OK so I got the "MoT" certificate.
Having fiddled around in sort of panic mode, I lost count of the needle turns which I'd set.
Is there a quick way I can just get back to a basic setting on both carbs by turning the needle fully in or out or whatever to then counting the turns as I enrichen or weaken the mixture? (I must have done this years ago when I set them up but have completely forgotten it having not done anything on the Stag for about 4 years due to house-building.)
Cheers in advance
Drew
Cheers in advance
Drew
