Does anyone have any information about the acceptable tolerance for the differing thickness of heads?
A cylinder head expert nearby has said that if there is any difference between the amount that has been skimmed off the heads it will result in crankshaft failure. I think my RH head has reached the end of its life, as it has 3 studs stuck in it & has been skimmed several times in the past, so I acquired another. The new head is however about 1mm thicker than the LH head, but when I measured the old RH head it in turn was about 1mm thinner than the LH - if you follow! The heads have been on (with the 1mm dif) for 20000 miles without any crankshaft problems, but I know the Stag used to have problems.
, avoid HGF, and be able to get a decent inlet manifold seal on both sides.
