Stag
    Stag
    thought you guys might like to see this, and who thought the Stag could not be modified, biggest engine i have seen in one so far
    I like.
      I think you will find that stoutgoose (Steve) also has a 5.0 in his stag all be it from a 1950's Buick pushrod engine
        It is David Graham's Stag intheUSA
        Colin
          is tha rad in the boot, blimey now that is what you call not a lot of room to work with, but i do like it i must say
            He doesn't appear to have any wipers........ presumably he doesn't want to see what he might hit, assuming he can see past the large bulge in the bonnet
                Alan,
                How about this one - 5.7 litre. Still a work in progress I believe.
                  A Ford small block V8 is not actually a large engine externally. I would think it is very comparable with the Stag engine. I think that the bore spacing is very similar, actually.
                  On top of that, a fully-dressed, all-cast iron Ford small block weighs about 450 pounds, versus 446 pounds for the Stag engine.
                  The Ford is narrower than the Chevrolet small block but slightly longer, from what I've read.
                  And the Ford small block can be stroked out to 347 cubic inches - 5.6 litres! 550 brake horsepower is trivial to these stroked motors too...
                  :dude:
                  Paul
                    As her in doors may say...."its all about size!"
                      ^^ It's not. It's what you do with it.
                      Paul
                        Paul
                        If they managed to squeeze one into the little Sunbeam Alpine, the Stag should be easy.
                          Awesome !
                            Wind the clock back ten - fifteen years, Richard Lane had a small block Chevy bored out to 6.3.
                              Yeah but you wouldn't want it as a spot on the end of your nose......!
