Just broke down on the M1, Tried to start it numerous times, occasionally car would start but only for a few seconds and ran very weakly until finally it wouldn't start at all.
Tried bashing the fuel pump and shorting the inertia switch out to no avail.
Came back on a breakdown wagon.
When I got it home and switched the ignition on I noticed the battery indicator didn't rise hardly at all although starter would turn over. I've got one of those battery chargers with a starter mode on it so I put that on and the fuel pump burst into life and the car started. I'm suspecting the fuel pump but now it's running I can't test it. Is it worth stripping the pump down to overhaul it or would you recommend changing it? If a change is required are there any pumps better than others, what do you recommend, Thanks Terry
