Hi all,
I'm nearly back on the road for full use again! You may remember I had a nasty incident with the crankshaft bolt a month ago so I've now got no engine driven fan, but a Kenlowe 16" mounted in front of the rad with a revotec adjustable thermostatic fan switch in a boss on the rad.
It was hot on sunday, and when I went out for a test drive I found the temp gauge rose to about 1 o'clock (its a mk1 gauge with the word "normal" in the middle - needle was pointing at the L) and stayed here the whole time. The electric fan is adjusted to kick in just after 12 o'clock so was running the whole time I was out. I have to admit I'm not particularly comfortable about this, 20amp draw on the alternator the whole time isnt great - I was hoping it would cut in and out but not be on all the time. There were a few times when the gauge when up even higher still (nearer to 2 o'clock) at which point I panicked, pulled over and checked under the bonnet to find no issues with water loss, over pressurising or anything.
So, some questions - hopefully someone can offer some helpful advice!
1. I'm now beginning to wonder whether an electric fan by itself is enough - I'm not sure the rad is big enough to cool just on air pressure when driving. (Its a brand new Supergill and the rest of the cooling system is totally clean and brand new);
2. I got a temp sender from Rimmers - but when looking on LDPart website noticed that they said the standard aftermarket ones read too high. I've bought his recommended replacement to try - do you think it could be this? I adjusted the fan switch going by the temp gauge so perhaps its just coming in too early and not as hot as the gauge would indicate.
My work has a thermal camera so I may be tempted to borrow this of a lunchtime and see what the temperatures really are across the rad and engine.
Thanks folks!
Thanks folks!
