Hi all,
I know this is a much discussed topic but I would really like to do something about the lack of feel I get through the steering. I've bought a spare rack and stripped the control valve down to see how it works. From what I can see the torsion bar is pinned to the splined input shaft at the top, and to the pinion shaft at the bottom with hardened steel roll pins. If these pins aren't tight the torsion bar does not turn right away when you begin to turn the steering wheel so what you end up with is power assistance coming in straight away and no physical connection to the pinion. I'm guessing that this is what makes racks get more and more assisted as they wear through use.
My first plan is to try to find slightly oversized roll pins to see if I can tighten up the connections to the torsion bar.
Plan 2 is to approach Adwest (the original manufacturer) to see if they would be interested in working with me to develop something that feels better - perhaps just a stiffer torsion bar. Looking at their products I notice they do a standard rack that looks similar to the Stag one which they claim is a universal offering, I wonder whether anything could be done to make the spool valve from that fit our racks.
Anyway this is all pure conjecture at the moment and I'm not at all sure if they'll be interested (suspect not). However, I think they would be more interested if I was after more than a 1-off, so as a quick gauge of opinion, could you let me know if you'd be interested in a modified spool valve?
Thanks.
P.S. I know that there is a school of thought that reducing pump pressure will help - I'm not sure that it will; you need to change the gain of the system, not the "input voltage" and the torsion bar is what sets this.
Thanks.
Martin.
