As all of you who've read my past posts know I've suffered from water loss since owning the stag. I've change all the hoses, the thermostat, the inlet manifold gaskets to no avail. On a recent run I broke down on the motorway when the fuel pump packed in. At the time the temp indicator was showing hotter than normal but I put this down to the hot weather. I've chaned the pump for an electronic one and at the same time decided to put some K-seal into the rad to try to stop the leak. Did that this morning and started the car up and left it running while I had a quick shower (less than 10 minutes ). When I came back to the car the temp was showing just short of going into the red. I let the car cool down and took it for a short run. In less than a mile it was back nearly into the red. Felt at the hoses, Top hose hot, bottom hose only warm. Could this indicate a blocked radiator. If so is it an easy and quick job to change the rad. Which rad is best ( at a reasonable price ). Is it better to get my rad re-cored. (It does look a bit scabby.
I'm now waiting for the car to cool down to check the water level.
While it was cooling down I wondered if I was getting a false reading from the temp gauge due to the voltage stabiliser. I'd ordered an electronic one but not fitted it. The old stabiliser has 2 double terminals. On the B side (battery), is a double dark green wire and a single dark green wire. With the ignition on and the stabiliser removed, the double dark green wire is at 12volts and the single dark green wire at 0 volts. On the I side of the stabiliser,(instruments), is a double light green wire, again with the old stabiliser removed the voltage here is also 12volts. With the old or new stabilisers fitted, the voltage at both sides is still 12volts. It should be 10volts on the I side. Also with no stabiliser fitted, the temp gauge and the fuel gauge read the same as when the stabiliser is in circuit. I'm now total confused. ( I'm even more confused now I've typed this out ) Can anybody help please, the summer is slipping away. Terry
