My car has started cutting out completely and will not restart, but eventually does. It is definitely an ignition problem. (My garage has tested it when it wouldn't start, and confirmed it is the ignition)
I had a lumenition optronic electronic ignition put on about a year ago. As a first step the coil has been replaced, but that didn't do the trick.
The electronic ignition has been back to lumenition, and been tested, and I am currently awaiting its return - apparently it has passed all the tests. I have bought a new rotor arm - on the old one the copper/brass bar has slight movement, but I find it hard to believe that this is the reason for the cutting out.
My garage has jiggled the ignition key when it is running, and this makes no difference.
Anybody any other suggestions, or is it going to be the rotor arm? I stillbelieve the electronic ignition itself is faulty, but they do say it is not.
