Oil in the vee
    Oil in the vee
    Hi all,
    Just got back from a 60 mile jaunt and the car ran sweet as a nut, except we kept getting a whiff of hot oil. Had a look when we got back and the smell seems to be due to a small amount of oil which is at the back of the vee, under the dizzy. Less than a tablespoon but obviously enough to waft the smell into the car when the engine's hot.
    Any idea's where it could be leakingfrom? I've had a good look and cannot see any obvious sources.
    Bob.
    It's normally the oil seal in the water pump or it could be a cam cover.
      Cam covers have new(ish) gaskets and are OK - first thing I checked. I will have a closer look at the water pump cover. Hopefully if it's that it won't get worse and I can live with it - don't fancy that job!
      Bob.
        Not sure if blueMK2 meant ' o' ring in the distributor. That is a possibility. I would wipe it all clean and warm it up in the garage and watch carefully, including using a small mirror in the vee pointing up the tunnel towards the water pump area.
        good hunting
        Peter f
          No the oil seal in the water pump, when they leak you get oil in the V.
            Junction between chain cover and headgasket .Thats where mine now has a slight leak since doing my chains:X.
            Cheers Steve
