Question re warm running
    My Mk1 is running really well when cold /warm, but on long runsparticularly on hot dayswhen in overdrive/4th and accelerating to go up hill, it occassionally "misses" tho very very briefly. It never happens at higher revs. Constant temp in all weathers is around < 90. I check my points gap regularly, have a new coil (2 months old) when ticking overand at low revs it passes the 50p balance test! and never happens when weather is cooler !!!Anyone had similar or any suggestions welcomed. Graham
    Hi Graham
    What do you mean by misses? Does it cut-out, sound laboured or just not run as smooth?
      Hi
      I suspect you have a HT lead breaking down, how old are they?
      Stuart
        Agree with Stuart - HT lead or plug is breaking down....
          Hi Graham
          It as if it misses justone ignition stroke, but there would be several in a 10 sec period if laboured for a long period!!
          Graham
            Hi Stuart
            Not sure about age of leads and plugs, the coil and condesor are just 2 months old tho
            Thanks All ...Ill try a new set of plugs and HT leads
            Graham
              Good luck.
              By the way, mine is an Isle of Wight car, supplied by Wadham Stringer in Newport originally on a personal plate, but now on a RDL index - it stayed on the island until just a few years ago.....
