Goodwood - Soft top Sunday 27th. June
    Hi,
    Is anyone going to 'Soft Top Sunday' Goodwood Breakfast club this weekend?
    I am hoping to go and the weather forecast is good.
    StagnJag wrote:
    Hi,
    Shame i can't make this one, weather is forcast to be 30, don't forget to be back in time for our win against the Germans.............................I hope
      Can't do this one, got Mum staying. Went down to Somerset yesterday and brought her back to ours today, then take her back on Sunday morning, turn and burn back home again (in time for the footy hopefully)- all in the Stag though
      Al.
      (assuming it passes mot on Sat!)
        Hi,
        Hoping nothing spoils my plans as I want to do this one, as a shake down before the Lemans Classic, so all going well I will see you there.
          Just got my gbox in a lot easier than expected so if i finish all the prop ,exhaust etc in the next couple of days i could be up for it.
          Cheers Steve
            Cheers Steve
            You're getting good at this, Steve.
            Went to Somerset yesterday, checked the oil this morning before driving back, and it was on the minimum, so oil leak getting worse:shock:I did tear the sump gasket when removing the rear oil seal housing last time, so might be that. Otherwise my box will be coming off again to check the crank rear oil seal:X
            Al.
              Cheers Steve
              Is this the modern clutch conversion?
                Arbman Al wrote:
                Cheers Steve
                Al.
                Bummer , gutted for you Al.I got the box back up in 5 minutes ,Sat it on trolley jack and got it close ,put cable ties through some of the bolt holes ,rotated the output with it in 4th and gave it a shake then tightened up the cable ties a bit more,did that a couple of times and it was there.
                Cheers Steve
                  StagnJag wrote:
                  Cheers Steve
                  No Dave it's a stop gap replacement of the thrust bearing .I have done all the measuring i needed to do for the modwhilst it was apart though.
                  Cheers Steve
                    5 minutes - fancy doing a pimento one Beer tokens available
                      Stagdad wrote:
                      Arbman Al wrote:
                      Cheers Steve
                      Al.
                      Cheers Steve
                      I find it's getting all the nuts and bolts back in that's the problem, rather than actually getting the box to line up.
                        I'll have to skip this one.... planning on getting mine closer to the road on Sunday and there is a certain football match which will require my full attention
                        ............Andy
                          I would love to go but unfortunately I have to go the the airport again Sunday morning.....
                            more Golf?
                            I'm away the following week but this time only playing in Wales, what a let down after 4 straight years in France, still Vegas next year
                              no golf this time... a week with the family instead.
